RedBatman89
Nov 09, 2018Guide
Address Reservation doesn't work for Samsung Smart TV
Hi so my Samsung TV will not work with the Address Reservation option in the router, it will actually change ip adresses amost daily, I normally don't use the samsung smart tv functions since I have ...
Nov 09, 2018Guru - Experienced User
What FW is currently loaded?
Is the TV FW up to date as well?
Do other devices work with a IP address reservation ON the router?
- RedBatman89Nov 09, 2018Guide
So my firmware is the current one and its only my TV doing it, no other device. Also my modem is an SB6190.
- FURRYe38Nov 10, 2018Guru - Experienced User
Can do this,
Set a new IP address pool on the Orbo to 192.168.1.100 to .200
Then set a Static IP address ON the TV out side of the pool mentioned above. Say 192.168.1.40, input 192.168.1.1 for the gateway and DNS, use same subnet mask as seen on the router. Save these settings ON the TV.
Let us know what happens.
Be aware of your ISP Modem:
https://badmodems.com/Forum/app.php/badmodems
