cpking
May 11, 2020Aspirant
admin password on orbi satellite (RBS20)
I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin pas...
May 11, 2020Guru - Experienced User
Be sure FW is the same on RBR and RBS...
cpking wrote:I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin password which I changed on the router is not syncing with the satellite. So, my router at 192.168.1.1 has credentials of admin|mynewpassword, and the satelitte at 192.168.1.8 has credentials of admin|myOLDpassword.
When using a browser to access the satellite, there is nowhere I can see to change the password. How do I change it?
