cpking
May 11, 2020Aspirant
admin password on orbi satellite (RBS20)
I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin pas...
May 11, 2020Guru - Experienced User
Be sure FW is the same on RBR and RBS...
cpking wrote:I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin password which I changed on the router is not syncing with the satellite. So, my router at 192.168.1.1 has credentials of admin|mynewpassword, and the satelitte at 192.168.1.8 has credentials of admin|myOLDpassword.
When using a browser to access the satellite, there is nowhere I can see to change the password. How do I change it?
snikker17
Dec 27, 2020Guide
"What is the distance between the router and satellite(s)?"
How does that even matter in this scenario? The mere fact that the satellite is online, viewable and reachable already proves that its connected on the same network so its quite obvious that distance cannot be an issue.
"Is the password you are using to access the RBS20 the same password that's on the RBR20?" If yes, then its likely the SAT is synced with the AP and not the router.
"Is the password on the new RBR20 AP the same as the RBR40?" If no, then again it points to the SAT likely being sync to AP and not Router. If yes, then there is a bigger issue because if RBR40(Router) and RBR20(AP) have same pwd and RBS20 doesnt, sync is failing.
- FURRYe38Dec 27, 2020Guru - Experienced User
Distance is a factor on ORBI systems. Too close or to far will cause the wifi overlap and connect between the RBR and RBS to be problematic...thus some will see odd problems like this. Also FW being not the same on the RBS can be problematic as well.
We already know that if the RBS PW is the same as the RBR, then the RBS has synced with the RBR correctly. Which seems to be a problem the OP posted about 6 months ago.
