Luvridge
Feb 09, 2023Follower
Admin password to access router
The 2 questions I am asked are not the ones I set up originally to access router. Default password won't work either. Will reset of router cause issues for reconnection?
CrimpOn
Feb 09, 2023Guru - Experienced User
If the router is configured with exactly the same WiFi SSID/password as before, then devices will reconnect automatically.
(Just personally) I find configuring the router with the web interface more reliable than using the Orbi 'app'.
