Homealone320
Nov 09, 2022Follower
Admin Password
I've changed my admin password. It works on my new ipad gen 5 but the password will not work on my galaxy S10 note plus. Any help is appreciated. I've restarted phone several times.
michaelkenward
Nov 11, 2022Guru - Experienced User
If you are talking a bout the wifi password, tell the Galaxy to forget its past wifi connections to the router and set it up again.
Otherwise, explain what you are doing and where it goes wrong. As CrimpOn says, your query is ambiguous.
