dwpenn
Oct 16, 2018Star
Admin vs admin
When I access the ORBI from my PC as 192.168.1.1 it opens with a pre-filled in sign-on User Name. The problem is the pte-filled name "admin" (the one that actually opens the file) appears as "Admin".
Am I going to have to change the case on the letter "a" manually as long as I own this product?
I can change it manually and successfully login, but the regular and advanced tools in the application only have a section that allows for PASSWORD change. Besides fixing the mixed case to lower case to make it work what if I wanted to actually use a real pronoun name? I don't see where I had a chance to name it, and I don't see wwhere Netgear allows me a chance to revise it.
1 Reply
clear your browser cache, exit the browser the re-open the broswer and type in the new correct "admin" and pw. the browser should ask you if you want to save the log in information. Try different browsers to test.
