jasperx
Sep 29, 2019Tutor
Administering Orbi router in AP with wired satellite backhaul
I used my laptop browser to reach the admin tools on orbilogin.net. The thought was to update to the latest firmware. My enthusiasm for the update was low because things have been working fine. Ri...
- Sep 29, 2019
CrimpOn's simple explanation for not reaching admin from wired is probably correct. I input the IP for the RBR and neatly reached the admin.
Half way there.... the firmware update page under advanced>administration is still showing waiting for connection for both RBS.
A closer look at the connected devices list is showing that all the devices in the house are connected to the RBR... nothing is connected to the RBSs. My recollection is that back when I was setting up the network the first few times that devices would show connection to an RBS or the RBR depending on what was closest.
It looks like perhaps the RBS may have gone offlne at some point and every thing jumped on the RBR. Then when the RBS came back on things stuck? But this does not explain why the RBS are not showing up on the Firmware update page. It is like they have been forgotton everywhere but the connected devices list.
CrimpOn
Sep 29, 2019Guru - Experienced User
There may be a simple explanation. When the laptop connected through the switch to the Pace router asks to resolve the name "orbilogin.net", the Pace router has no idea where that is. When you connect to the Orbi WiFi, even though it is in AP mode, the WiFi part of Orbi knows that "orbilogin.net" refers to the Orbi router.
My bet is that you can connect to the Orbi using the actual IP address of the Orbi router, not the name. It should be 192.168.1.<something>.
As far as updating, once you are connected by ethernet, there is no need to walk around updating. You certainly can connect directly to satellites and the Orbi router using their LAN ports if you want to. You will still have to connect to their individual IP addresses with a web browser to do the update.
jasperx
Sep 29, 2019Tutor
- CrimpOnSep 29, 2019Guru - Experienced User
I wonder what "Waiting for connection" means. On the software update web page, it clearly shows the firmware release of each satellite. The Attached Devices says the satellites are "wired" and "good".
I have a suspicion is the "waiting" message refers to the Netgear firmware site. Sometimes this takes a bit. Strange that it clearly shows the new router firware release but seems to hang up looking for the satellites.
As for devices switching to the router and sticking, that could well be true. An easy test is to power cycle one of the devices that used to connect to a satellite and see what it picks when it comes back on. Some people go so far as to "forget" the Orbi WiFi and then do a new scan (under the assumption that the device has learned the MAC address it prefers and will go back to it if it is still there).
- jasperxSep 29, 2019Tutor
Somewhere along the line the Orbi Router and the network switch both got directly connected to the Pace Modem Router. I put the switch (with its connected Orbi satellites) back downstream of the Orbi Router and everything started working as expected. The firmware updated without a hitch and a power cycle of most of the devices has them connecting to the nearest satellite.
Connecting directly to the Orbi Router using the IP address was the key I needed to start getting things sorted out. Thanks a bunch.
