Mettaman
Jul 20, 2017Aspirant
Adobe Walls in New Mexico
I live in a 2,000 sq. foot adobe wall home with 2 external studio spaces. One space (200 sq. ft.) s 25 yards from home the second (1000 sq. ft.) is 75 yards from home. Internet signal from Century Li...
st_shaw
Jul 21, 2017Master
It's not likely to work well. Too far away. Adobe walls will probably block most of the WiFi signal as well.
If you want connectivity at the external studios, and you truly cannot run a wire, then your best option is a point-to-point wireless bridge between the buildings. Something like the Ubiquiti Nanobeam should work.
Mettaman
Jul 21, 2017Aspirant
Thanks for the point-to-point suggestion. I'm going to contact Ubiquiti and ask if they can recommend an installer in the Santa Fe area.
