StrikerXtreem's avatar
Mar 04, 2018
Advanced settings gone on my Orbi
My initial problem was that I have a Chord Polly that only can connect on 2.4 Ghz and the setup has to connect on the same bandwith with my iPhone. So I look and found out that it was possible in the...
  • Alextheangel's avatar
    Mar 04, 2018
    You should go to Advanced Setup-> wireless setup instead.
