Kerry2U
Oct 12, 2020Follower
Advanced Setup App for Orbi RBK50
Hello all, Is there an app that can be downloaded to access advanced setting in the orbi rbk50? The settings available are not going to cut it. I need to be able to forward ports, open and clos...
Oct 12, 2020Guru - Experienced User
The RBRs web page does this. You can setup the RBR for your needs and onces it all setup, do a back up configuration to file for safe keeping. You can use this backup file to re-load the RBR or even a different RBR.
