ama1942
Jan 21, 2018Aspirant
Advanced Wireless Settings
Hello, I just bought the RBK40 and it works fine, I updated to the latest firmware and I noticed these 3 options in the web interface : Advanced -> Advanced Setup -> Wireless Settings : - Enabl...
KBeatty
Jan 23, 2018Tutor
You won't find any great answers on these. If you have a MU-MIMO device (they're rare atm), then you definitely want it enabled. Implicit beamforming also helps a bit with slighly older wi-fi devices, so it's worth enabling as well.
However, my understanding is they were causing some disconnect issues in earlier firmware releases so Netgear disabled them by default. FWIW, I have both on and have no issues.
As for fast roaming, I have that disabled. Other users have complained it causes devices to be a bit too agressive in switching between satellites and router causing unnecessary hiccups in connection. Since I have no probelm currently with how my network peforms, I've just left that alone.
ama1942
Jan 23, 2018Aspirant
Thank you KBeatty, it's nice to share your settings and experience.
Right now i have no problem at all, the system is working fine for me.
I initially read an article about the Orbi explaining that the system was the best in its class, so I first installed a RBK40 for a friend of mine and it's working fine since about two months (his previous wifi box was simply horrible), then last saturday I bought mine. I did'nt know about problems with Orbi but I noticed that a lot of people complaining have RBK53...
Anyway I will keep in mind the possible issue with fast roaming ... I will let it enable right now
