bbb555
Mar 04, 2024Tutor
Advice please: Unavailable RBR50 RMA to be replaced with an RBR40
My RBR50v2 has issues with constant rebooting. After following related posts here and raising a support ticket (still under warranty), Netgear support stated it needed to be replaced and an RMA setu...
Mar 05, 2024Guru - Experienced User
what speeds do you pay for?
Are you using a wired backhaul?
If you're ISP speeds are low enough or you have a hardwired backhaul, you won't notice much difference.
Its once you're getting past that 400-500mbps speeds through the wireless backhaul that the wider backhaul makes a difference.
