bbb555
Mar 04, 2024Tutor
Advice please: Unavailable RBR50 RMA to be replaced with an RBR40
My RBR50v2 has issues with constant rebooting. After following related posts here and raising a support ticket (still under warranty), Netgear support stated it needed to be replaced and an RMA setu...
bbb555
Mar 26, 2024Tutor
thanks for the replies, just thought I'd give an update.
I ended up going back to the retailer I bought it from and told them what I've gone through with support and the RMA.
The retailer has offered a RBK352 as a replacement instead. It is dual band (but I use a wired backhaul) and has WiFi 6, so I've gone with that option instead.
Hopefully this lasts longer than my RBR50v2.
