meanjeanslo
Oct 17, 2023Guide
After firmware update - satellite disconnected and unable to reconnect
Hello, I have an Orbi RBK20 set with a router RBR20 and 1 satellite RBS20. I downloaded and installed the most recent firmware V2.7.4.24. The router updated fine and still works/connects. I am cu...
- Oct 28, 2023
Just wanted to make my final post on this. I truly appreciate all of the feedback I received which helped me troubleshoot!
After all of the troubleshooting and not being able to get this to connect, I finally decided to quit trying with it. It was a great system as long as I had it and I'm sure glad I ordered a newer model for my house. I was able to give my neighbors the router to use in AB mode and it's cleared up their cable TV issues so I think it's still a win.
Thanks again!
Oct 17, 2023Guru - Experienced User
Look for the RBS on the routers web page under Basic tab/Attached Devices.
Also be sure to update any and all RBS FIRST, then the RBR lastly.
meanjeanslo wrote:
Hello,
I have an Orbi RBK20 set with a router RBR20 and 1 satellite RBS20. I downloaded and installed the most recent firmware V2.7.4.24. The router updated fine and still works/connects. I am currently using it in AP mode and using my Netgear Nighthawk RAX20 as the main router because it offers Readyshare for attached storage.
After I ran the download and install using the internet connection, my satellite lost connection and turned magenta on top. So I thought I would just disconnect it and reconnect as I did the very first time, but now I can't connect the satellite at all. I tried using both the app and the web interface, as well as just hitting the Sync buttons on both router and satellite. None of this has worked.
Next, I tried using the reset for each device, first the satellite only, then also the router. Still, the satellite won't connect. The app can't see it and the router isn't finding it, either. I ran an ethernet cable to it so it's showing on the network, but still not connecting via wifi.
Is there anything else that I can try to get this working again? I was wondering if I can push a manual firmware update to it but haven't been able to locate a solution for that.
Ideas, thoughts? I'm attaching a screenshot from within the Orbi RBR20 that shows attached devices, excluding MAC addresses. Not sure if this helps, but wanted to try.
Thanks, I appreciate any assistance someone with more experience is willing to give.
I should also mention that I bought another set of Orbi's RBX50 so the 1.120 and 1.5 ip addresses that you see are those. I plan to give this old set to my neighbors who have terrible internet connection in their home.
meanjeanslo
Oct 19, 2023Guide
I don't see a button that says "Connected Clients" and when I click on Attached Devices, the only options I have for that device since it's connected with an ethernet cable is to change the name and device type. I'm not able to connect it via wifi at all.
- KevinLiTOct 19, 2023NETGEAR Moderator
Hello meanjeanslo ,
Thank you for the update!
This behavior is usually observed when the satellite and the router are on different firmware versions. Please ensure that the firmware of your satellite is the same as the firmware on your router. If it is not on the same firmware, please update your satellite once you get access to the satellite admin page.
Please follow the steps below to verify your satellite firmware:
- Connect directly to the satellite via an ethernet port.
- Navigate to 192.168.1.250.
- Log in with your router admin credentials (If you tried a factory reset the password may revert back to the default password. Try both!).
- Finally, the upper left of the browser will show the firmware information.
Please follow the link below for instructions on manually updating your RBS20:
Best,
Kevin
Community Team
- meanjeansloOct 19, 2023Guide
Unfortunately, I am unable to connect to the satellite via a web browser and the ethernet cable. Not sure what is wrong with this device. It's certainly malfunctioning. Here is the screenshot from the router showing that it's not connected there, followed by the browser when I type in the IP, followed by a command prompt where I ping that address and it is able to connect.
I have the firmware downloaded to my computer but don't know how else to install it onto the satellite.
Thanks again for everyone's input!
Hello meanjeanslo ,
Can you select the manual tab and take a screen shot?
Best,
Kevin
Community Team
