Wan21's avatar
Wan21
Follower
Aug 31, 2020
After firmware update unable to locate AC2200 rbr20 2.4 band
Our Switch is connected to it but other than that you can not see it on any other devices to be able to connect to it
1 Reply
  • plemans's avatar
    the RBR20 uses bandsteer and single ssid function. Meaning it uses the same ssid for 5ghz as it does for 2.4ghz.
