DROBICEK
Nov 29, 2016Tutor
after FW 1.4.0.16 loosing satellite
Hello,after upgrade firwmare to 1.4.0.16 to unite Satellite.Solid white and green flash.Ping 192.168.1.1 works,not web interface,not connection to RBR50. Sorry me for my clumsy english. Please help...
DarrenM
Dec 01, 2016Sr. NETGEAR Moderator
Hello Drobicek
So after you upgraded the unit to 1.4.0.16 the satellite will not connect to the base? Have you tried to press the sync button on both units? Have you tried bringing the satellite closer to the base? You may even need to factory reset the unit after doing the Firmware upgrade.
DarrenM
- DROBICEKDec 01, 2016Tutor
- DarrenMDec 01, 2016Sr. NETGEAR Moderator
Hello DroBicek
I would suggest contacting support they will be able to troubleshoot the issue with you.
https://www.netgear.com/support/contact
DarrenM
