DROBICEK
Nov 29, 2016Tutor
after FW 1.4.0.16 loosing satellite
Hello,after upgrade firwmare to 1.4.0.16 to unite Satellite.Solid white and green flash.Ping 192.168.1.1 works,not web interface,not connection to RBR50. Sorry me for my clumsy english. Please help...
Miles267
Dec 18, 2016Apprentice
Unfortunately v1.4.0.18 did not resolve this issue for me in AP Mode. Main unit and satellite do not sync. Satellite continues to flash white and never turns blue.
- twocybersDec 29, 2016Star
Have you upgraded the router and satallitie(s) to 1.4.0.18? I thought I had done that and discovered I had only upgraded the base station. Apparently you can only upgrade one physical device at a time.
And interestingly the release notes specifically mention keeping satallites in sync.
Below are links for both base station and satillite updates.
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.4.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.4.0.18.zip
Here is a link to the download center generally -
- ima49erJan 08, 2017Tutor
There is now a newer version V1.4.0.34
It appears that the issue may have been with the status lights, not with the actual sync capability. I discovered this by accident when I unplugged the satellite to add a surge protector. Even though the light turned 'magenta' (pink) after the satellite rebooted, my desktop PC immediately had internet access via the ethernet connection to the satellite. Tested on speedtest.net and got 120.62 download and 6.33 upload. Obviously, it had perfect connectivity to the router, just didn't have the correct color light. http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.4.0.34.zip solved the issue
