wisetulip
Feb 15, 2021Tutor
after update of firmware
I updated my firmware on Orbi RBR20 since i am unable to see both icons for router and sattelite on iphone app. i just see text " Satelite 1" and the modem with waves around it. the update was done...
- Feb 15, 2021
Have you powered OFF the ISP Modem and RBR for 30 seconds then back on with the modem first, then the RBR?
How was the system updated? Orbi app or thru the RBRs web page?
Feb 15, 2021Guru - Experienced User
- wisetulipFeb 15, 2021Tutor
Your solution worked thank you very much
- FURRYe38Feb 15, 2021Guru - Experienced User
Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
"Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed."
how do I perform above on iphone app? i can only access/view my account on iphone app.
the login.net only brings up the netgear website now.
