Rkujay
May 20, 2019Aspirant
After update, rbk50 won't allow dlink 942l to go online
May 20, 2019Guru - Experienced User
Factory reset and setup from scratch using same SSID and PW from before? Ive had no issues with my 3 DCS cameras working with Orbi after a FW update, factory reset and setup from scratch using same SSID name and PW.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
- RkujayMay 21, 2019Aspirant
Harris modem provided by Frontier fios. Loads of nearby secure networks. House is 3k square feet.
