Rkujay
May 20, 2019Aspirant
After update, rbk50 won't allow dlink 942l to go online
CrimpOn
May 20, 2019Guru - Experienced User
A little more information would be helpful. So, the Orbi "Attached Devices" page does not show the DLink camera as being connected? This is the only WiFi device that has a problem after the firmware update? How many WiFi devices are on the network and have you done extensive customizing (giving devices unique names, assigning IP addresses, setting up ports, etc.)? If not, then a "factory reset" is often a good idea to "clear out the debris" from months of activity and get a clean start. If you have, then the factory reset is seen as quite a chore and usually left as a last resort.
My first step would be to go through the camera startup from scratch. i.e. plug in an ethernet cord, and follow the directions.
- RkujayMay 21, 2019Aspirant
Windows 10 and current. Orbi is current. These two dlink 942L are the only devices not working. Orbi can see them, but they do not go online. There are 12 devices on the network. Not all devices are working simultaneously.
- FURRYe38May 21, 2019Guru - Experienced User
There a model # of the FIOS modem?
What happens if you temporarily disable WPA security on the Orbi. Do the cameras connect then? Re-enable WPA2 and AES only after trying this.
Set manual channel 1, 6 or 11 on 2.4ghz.
Have you reset the cameras and connect them again to the Orbi? Disable the 5Ghz SSID broadcast before you set them up, Under Advanced Tab/Advanced Settings/Wireless Settings.Ensure the cameras FW is up to date as well.
Something you may want to post over on D-Link forum since this maybe a D-Link issue.
