Rkujay
May 20, 2019Aspirant
After update, rbk50 won't allow dlink 942l to go online
Rkujay
May 21, 2019Aspirant
Windows 10 and current. Orbi is current. These two dlink 942L are the only devices not working. Orbi can see them, but they do not go online. There are 12 devices on the network. Not all devices are working simultaneously.
May 21, 2019Guru - Experienced User
There a model # of the FIOS modem?
What happens if you temporarily disable WPA security on the Orbi. Do the cameras connect then? Re-enable WPA2 and AES only after trying this.
Set manual channel 1, 6 or 11 on 2.4ghz.
Have you reset the cameras and connect them again to the Orbi? Disable the 5Ghz SSID broadcast before you set them up, Under Advanced Tab/Advanced Settings/Wireless Settings.
Ensure the cameras FW is up to date as well.
Something you may want to post over on D-Link forum since this maybe a D-Link issue.
