sojourn_out
Dec 30, 2019Aspirant
Airbnb Internet Options (6,000 sq ft.)
Hello! I am a property manager for a 6,000 sq. ft. Airbnb property. I have been working with different wifi pods/extenders to help increase connectivity and speed for my guests. These have not ...
tomschmidt
Dec 30, 2019Virtuoso
It looks like your exterior walls are concrete block. WiFi signal strength will diminish going through those walls. With the layout you have, if you can put the router toward the center and the two satellites towards each end, it should cover the space pretty good. Attached is a pic of this.
My home is concrete block, and the signal to outside is reduced, but is still quite strong to cover my needs.
sojourn_out
tomschmidt
Thank you so much! I will do that, and let you all know how it goes.
