Zamzoo
Jan 05, 2019Aspirant
Airplay 2 question - does it work well?
Not bought one yet, but currently a Velop refugee who is sending that back after the poor airplay (1/2) support and being told by Linksys to contect the Airplay vendor for a fix..
Does aiplay w...
Zamzoo
Jan 06, 2019Aspirant
Hmm, with apple TV you may be sitting still while streaming right?
The issues I'm trying to avoid is where you're moving around (even in the same room) and get dropouts - potentially when you move from one node to another.
ekhalil
Jan 06, 2019Master
I think that the drops while roaming depends much on the device and how it handles roaming and if it supports all the roaming enhancement standards. I believe that if there are mobility drops then you would see this in all other applications not only Airplay!
In Orbi it's just important to have enough overlaping between the nodes to make roaming possible.
Please have a look at this briefing regarding roaming in Orbi: https://community.netgear.com/t5/Orbi/Roaming-in-Orbi-and-Roaming-Enhancement-Standards/m-p/1680947#M48135
