Zamzoo
Jan 05, 2019Aspirant
Airplay 2 question - does it work well?
Not bought one yet, but currently a Velop refugee who is sending that back after the poor airplay (1/2) support and being told by Linksys to contect the Airplay vendor for a fix..
Does aiplay w...
DavidmCA
Jun 16, 2019Aspirant
I have been using Orbi with airplay for a while I have Apple TV’s and Sonos one speakers I have no trouble with roaming in the house or most of the backyard if I have good connection I rarely hear gaps or skips
perhorn
Jun 16, 2019Tutor
...but when will they create and sell the Orbi voice/speaker/router that can play as a Airplay2 speaker (and with a better sound wuality then the tests indicate the current avaiable android protocol plays)?
