Shof
Apr 08, 2020Aspirant
Airplay connection issues with Orbi
Greeting Netgear community, I recently purchased and installed an Orbi system with two satellites. It has been a great addition and works great for wifi in general. One thing I can struggling with is ...
Shof
Apr 23, 2020Aspirant
I communicated with Denon and as expected they put the blame on Apple AirPlay and essentially washed their hands of it. That will certainly be remembered during my next AVR purchase.
Anyway, I took the expensive way out and purchased a Sonos Port. This thing works amazingly well with Orbi and streams pretty much anything you throw at it, including anything AirPlay2 compatible. Don’t mean to be advertising another company’s product on a NG thread, but it works well with Orbi and solved my Denon headache so worth the cost. It even converts digital signal to analog if necessary (which I needed).
Apr 23, 2020Guru - Experienced User
Thanks for letting us know.
