Shof
Apr 08, 2020Aspirant
Airplay connection issues with Orbi
Greeting Netgear community, I recently purchased and installed an Orbi system with two satellites. It has been a great addition and works great for wifi in general. One thing I can struggling with is ...
Nyane
May 02, 2020Tutor
In case anyone was searching for the answer. I have found my problem. The Hegel was plugged into a Switch which was causing the issue. Once i connect the Hegel directly to the port of the Orbi, no airplay dropouts and airplay worked perfectly.
- FURRYe38May 03, 2020Guru - Experienced User
Glad you found the fix for this in your configuration. Odd that switches would do this unless it's a bad switch.
Thanks for sharing.
Enjoy. :smileywink:
Nyane wrote:
In case anyone was searching for the answer. I have found my problem. The Hegel was plugged into a Switch which was causing the issue. Once i connect the Hegel directly to the port of the Orbi, no airplay dropouts and airplay worked perfectly. - JevatyAug 30, 2020InitiateI had the same air play connectivity issue when I recently installed a new elan video/audio switcher. When I finally unplugged all Apple TV’s from switch (that I have used for years) and plugged directly into Orbi the problem resolved.
- FURRYe38Aug 30, 2020Guru - Experienced User
What is the mfr and model# of this switch you've been using?
Thanks for sharing.
Enjoy.
Jevaty wrote:
I had the same air play connectivity issue when I recently installed a new elan video/audio switcher. When I finally unplugged all Apple TV’s from switch (that I have used for years) and plugged directly into Orbi the problem resolved.- JevatyAug 30, 2020InitiateNetgear Prosafe 16 port. GS116
