Shof
Apr 08, 2020Aspirant
Airplay connection issues with Orbi
Greeting Netgear community, I recently purchased and installed an Orbi system with two satellites. It has been a great addition and works great for wifi in general. One thing I can struggling with is ...
Nyane
May 02, 2020Tutor
In case anyone was searching for the answer. I have found my problem. The Hegel was plugged into a Switch which was causing the issue. Once i connect the Hegel directly to the port of the Orbi, no airplay dropouts and airplay worked perfectly.
May 03, 2020Guru - Experienced User
Glad you found the fix for this in your configuration. Odd that switches would do this unless it's a bad switch.
Thanks for sharing.
Enjoy. :smileywink:
