Ohayogozaimas
Dec 29, 2020Aspirant
Airprint not working with Netgear ORBI RBR850
Hi Guys,
I am wondering if you guys could help me here. I have encounter issue with Airprint using the newly purchased Netgear ORBI RBR850 router with 2 satelites RBS850. Airprint doesn't works on all my iphones and ipad. My printer is Epson L6190. I have no issue with airprint previously using Google Router. I connected another Canon Sephy printer and airrpint able to locate it immediately. I have tried the following troubleshooting steps including approaching netgear support but to no avail. Troubleshooting steps as following.
- Turn on only 2.4Ghz and disable 5Ghz as the printer is running on 2.4Ghz.
- Disable AX function
- Disable Netgear armor
- Changing the router from Router mode to AP mode.
- Enabling RIP_2M
- Changing the channel of 2.4Ghz and 5Ghz
- Reducing 5Ghz strength to 50%
- Resetting the printer and all the routers and satelite.
- Changing CTS / RTS value to 2304
- Making sure all fireware of router and satelite are up to date.
- Reflash the firmware although it is the same version.
Am wondering if anyone can help to resolve this issue? Or is there a compatibility issue between Netgear and Epson?
1 Reply
Please post about this over inthe Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
