Instarand's avatar
Instarand
Alarm components need 2.4GHZ - help!
Hi folks. I have a Frontpoint alarm system. The main alarm panel (brain of the system) needs to be on the same frequency as the keypad (device used to engage and disengage the alarm with the code). Th...
