OrbiHelp
Feb 21, 2022Aspirant
Alexa connected satellite (RBS40V) stopped connecting to RBR20
All of the sudden my Alexa connected sattelite (RBS40V) quit connecting to the router (RBR20). I've tried all the tricks (powering off, reset button, etc). It shows up on my network map on the Orbi...
OrbiHelp
Feb 23, 2022Aspirant
So I guess maybe I need to start all over... I cannot get into the admin site and when I try the answers I set up, it doesn't recognize them. Do I need to do a complete factory re-set? And if so, how do I do that?
Again when I try to set up the satellite, I do not see that as an option on the Orbi app.
This is getting REALLY frustrating. Thank you!
CrimpOn
Feb 23, 2022Guru - Experienced User
Yes, a Factory reset is the only way to access the Orbi web interface when the web password is not recognized.
https://www.youtube.com/watch?v=cMw4ePACgc4
On the Orbi app, press on the icon in the upper left, a circle with either a tiiny house or a tiny cloud inside it.
Add a Satellite is the third item in the menu.
