Icycool
Mar 04, 2021Aspirant
Alexa on my RBS40V cant find any of my devices
All the other alexas find my devices, but the Orbi device keeps responding - did you mean first plug and then says it cant find the device. I've restarted the router, it's happening with V 2.6.2.4. A...
CrimpOn
Mar 04, 2021Guru - Experienced User
There have been several posts describing Alexa on the Orbi Voice as not being capable of much.
Netgear has a community forum specifically for the Orbi Voice. Maybe if the question is posted in that forum someone will have answers.
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
I have only used Alexa to play music on Orbi Voice,so I will be interested in what you discover about other "skills" (is that the correct term?)
Icycool
Mar 08, 2021Aspirant
It used to work before. But stopped in the last 2 weeks. Not sure if it had to do with the latest FW upgrade. But thanks for the note on the specific forum, I'll ask there too!
