Stopforth
Oct 19, 2019Aspirant
Alexa won’t communicate on Orbi Voice
Hi All, Ordered the Orbi router and Orbi voice and set it up to function for the most part, however after logging into my amazon account and ‘alexa’ saying she is ready to be asked about the weathe...
michaelkenward
Oct 20, 2019Guru - Experienced User
Can you conect tki the wifi from the voice satellite? That would confirm that it is set up and running properly as a satellite.
Have you installed the various Orbi and Alexa apps and skills? Set up a NETGEAR account?
There is support for the RBS40V, including manuals, at the end of this link:
>>> Orbi RBS40V | WiFi System | NETGEAR Support<<<
See the section Add Amazon Alexa to Your Orbi Voice.
Stopforth
Oct 20, 2019Aspirant
Thanks,
Unfortunately none of these things worked but I called and they helped fix things. It was a strange one. Went through one by one and the router was outputting a WiFi signal to the satellite but was saying offline on the app so it couldn’t all communicate
