wegunterjr's avatar
Oct 28, 2022
all devices say "the device is blocked by access control in the router" - hacked?!
How do I know if someone changed this? Did someone get access to my Remote Anywhere login??
I wanted to use a device on my network, but I noticed it didn't have internet connect, so I tried to use a browser and got the message"   device is blocked by access control in the router"
Only solution was a factory reset and to start setup again.
1 Reply
  • plemans's avatar
    Did you factory reset it?
    if so, not much to do as it should be resolved.
    If not, you should be able to change it from a device that can already access the router.
