djkac
Feb 18, 2019Tutor
All devices show connected to router in mobile app but not in PC
When I log in to the mobile app, it shows all the devices connected to the router and none to the two satallites. When I connect to the router from my PC, it shows devices are connected to the satall...
- Mar 01, 2019
Sorry for my late reply. I did go home to check this and found that Daisy Chain WAS off. I think a day or 2 later, there was an update pushed to iOS. Since then, it's been fine.
djkac
Feb 18, 2019Tutor
I pulled down on the Network Map and got the little refresh ring at the top. Once that updated, there was no change. The satallites say "No connected device found".
ekhalil
Feb 18, 2019Master
- Is this for wired devices or even wireless?
- There is a similar issue in the Android app that I never saw for IOS app, where the app gets confused when the SSID name (or the satellites' names) has spaces. Can you please check this and test to change that to see if it's a similar issue.
- djkacFeb 18, 2019Tutor
Niether wired or even wirelss show in the list. All I see is text that reads "No Connected Devices Found". One satallite is wired, one is wireless.
I checked the satallite names. One is called "Basement" the other was called "2nd Floor". I changed the name to "2ndFloor" with no space then closed the app and relaunched it. No change. Still "No Connected Devices Found".
- ekhalilFeb 18, 2019Master
djkac wrote:
....... One satallite is wired, one is wireless.
Please disable Daisy Chain in Advanced Wireless Settings.
I'll check this when I get home tonight. I can't seem to access that setting from the mobile app. I'm almost positive I have that off already. I'll confirm and get back. Thanks for chiming in!
