Pentotark's avatar
Pentotark
Initiate
Mar 15, 2022
All local PC and severs connected to orbi are unreachable
Hi I own an orbi mesh with 2 satellites. I would like to use it to extend the ethernet capabilities of my network and reach  2 wired PCs, one of witch is a plex server. My main router (provided by th...
  • plemans's avatar
    Mar 15, 2022
    Its because you're running 2x routers on your network causing a double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
