Guytas
Oct 08, 2020Aspirant
Allowing access to only one site with RBR50
is there a way to configure the router to allow internet access to only one ip address? It is important that the local network has full access internally between each devices. But every devices (wifi...
Mstrbig
Oct 08, 2020Master
Guytas wrote:is there a way to configure the router to allow internet access to only one ip address? It is important that the local network has full access internally between each devices. But every devices (wifi and wired) must be blocked to the internet except one or two sites.
if this rbr50 cannot do it, which one can?
ps: obviously online services are out of the question. This must be handle by the router (or a device between the router and the wan).
Don't see a provision on an Orbi device.
You would have to set it up a proxy server, block all traffic, except the ip addresses you want to allow access to.
