Guytas
Oct 08, 2020Aspirant
Allowing access to only one site with RBR50
is there a way to configure the router to allow internet access to only one ip address? It is important that the local network has full access internally between each devices. But every devices (wifi...
Guytas
Thank you very much you two. This is a lot of information. It sounds a good solution.
the router you referred.. is this one ok?
thabks again and I'll get to it now....
CrimpOn
Oct 09, 2020Guru - Experienced User
Guytas wrote:thanks again and I'll get to it now....
All I know about the product is that there have been several posts mentioning using it for one purpose or another.
Some years ago, I needed to restrict a computer to access with only a certain IP addresss.
Since I alone had the administrative login to a Windows computer, I used the Windows Firewall to set up rules that controlled which IP addresses could access it (and it could access). People who had "regular user" account could not change the firewall settings.
Good Luck
