trcy923
Dec 28, 2020Aspirant
allowing ports on orbit router
How can I open ports to allow roomba to connect to wifi?
Dec 28, 2020Guru - Experienced User
What model Orbi do you have?
Ports shouldn't be opened for the Roomba to connect. Is the Roomba a 2.4Ghz only devices or a dual band device?
Does the Roomba see the wifi SSID name at all?
trcy923
Orbi RBR40
Only runs on 2.4
internet access is metronet
Called Roomba mutiple times and was told firewall is preventing and that certain ports need to be open. Netgear is out of customer support and they want $168 to open ports
- FURRYe38Dec 28, 2020Guru - Experienced User
So the Roomba connects however does not get any Roomba services thru the orbi?
- trcy923Dec 28, 2020Aspirant
I can see the roomba on my phone but does not connect to the vacuum. I believe the modem is technicolor model VEN501-NA
What mode is your modem working in? It's a modem with built in router and wifi I believe.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou can try this to see if your phone and Roomba app connects to the Roomba
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
