Anonymous
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
farfromovin
Jan 25, 2017Guide
I do not use implicit beamforming. Everything works awesome without that option and relying on the "explicit" beamforming that is enabled by default. Or at least that's what I've learned here on the forums, that explicit beamformingwas part of the AC wave 2 standard that Orbi complies with. Implicit is just Netgear's attempt to get more modern wifi performance on legacy devices and can cause issues with some manufacturers. I don't need that "extra" feature.
- AnonymousJan 26, 2017
Hmmm, mine is still turned on. I know when I turned it off the speeds dropped dramatically on speed tests. I may have to try it again.
- brasaxJan 26, 2017Apprentice
I tried everything that was possible and mentioned here in the forums and nothing was helping. My iOS devices frequently reconnecting.. As I mentioned I'm in contact with the Netgear Support and I opened also a defect at Apple. But to be honest I do not think it is an issue at Apple side as I never had the probelms with my Time Capsule.
- DarrenMJan 31, 2017Sr. NETGEAR Moderator
We are aware of some customers having issues with IOS devices and are working to fix the issue.
DarrenM
