Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Jan 26, 2017Hmmm, mine is still turned on. I know when I turned it off the speeds dropped dramatically on speed tests. I may have to try it again.
brasax
Jan 26, 2017Apprentice
I tried everything that was possible and mentioned here in the forums and nothing was helping. My iOS devices frequently reconnecting.. As I mentioned I'm in contact with the Netgear Support and I opened also a defect at Apple. But to be honest I do not think it is an issue at Apple side as I never had the probelms with my Time Capsule.
- DarrenMJan 31, 2017Sr. NETGEAR Moderator
We are aware of some customers having issues with IOS devices and are working to fix the issue.
DarrenM
- bobby35nyJan 31, 2017Star
Sure hope you guys are working on the Andriod fix too!!
-bobby
- peteytestingJan 31, 2017Hero
brasax wrote:I tried everything that was possible and mentioned here in the forums and nothing was helping. My iOS devices frequently reconnecting.. As I mentioned I'm in contact with the Netgear Support and I opened also a defect at Apple. But to be honest I do not think it is an issue at Apple side as I never had the probelms with my Time Capsule.
ah but thats cause the TC is also apple
the issue is more that apple devices have always been an issue on none apple wifi , its just apple's way of forcing you to use all apple products
