Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Feb 06, 2017It is and will be resolved by the firmware on the orbi. I for one have had no issues with any other router with my android or Apple devices. This is only with this router.
peteytesting
Feb 06, 2017Hero
prob because its the first router you have use with nodes or more and same ssid
there is certainly something that apple does that upsets the cart so to speak , its a matter of finding out what it is and crippling the orbi somehow to make it work with apple products , in the past it was to force 2.4 gig to 20mhz mode only
