Retired_Member
Jan 25, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Draxxus
Feb 10, 2017Initiate
My experience with Netgear has been lack luster at best. I'm having frequent drops on my Samsung TVs and some of my Apple devices. I cannot get an Aruba RAP-3WN for VPN to work at all. Dyndns is broke as well. I really needed the extra LAN ports, which is why I opted for this solution over others. I guess I can live with buying some extra GigE switches and go the Linksys Velop route. PC Mag did a great review on all of the current systems. Velop > Orbi.
http://www.pcmag.com/review/350691/linksys-velop
B747driver
Feb 10, 2017Star
Draxxus wrote:I guess I can live with buying some extra GigE switches and go the Linksys Velop route. PC Mag did a great review on all of the current systems. Velop > Orbi.
I hope you have better luck than I did. Velop was a nightmare right out of the box. Tech support was willing to help but nothing seemed to work. I gave up and took it back after two days.
- Silver0066Feb 11, 2017Apprentice
Velop was a nightmare for me also. Tech support was awful, no User Manual, software full of bugs. I took it back and got the Orbi which I am very happy with.
- brasaxFeb 12, 2017Apprentice
Not only iOS devices have problems, also the satelite has no stable connection.
In 16 hrs the satellite was reconnecting 69 times. At start it shows a solid blue light, so the connection should be good enough.
- MacklemonsterFeb 12, 2017Star
Just registered to post I'm also having non-stop issues too. My iPad disconnects from wifi constantly, as does the dropcam camera we have. Everything else seems to be working fine, including iPhones, Apple TV, wifi thermostats, etc. the iPad and dropcam constantly disconnect to the point where I can't do anything on the iPad that requires a connection for more than five minutes. I get the wifi disconnect emails from dropcam throughout the day.
Really frustating.
