Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Feb 21, 2017Yeah, I don't have the luxury of wiring stuff in my house. So I will have to do some research on the other ones. Google wifi, Eero, etc.
brasax
Feb 21, 2017Apprentice
have a look at Amplifi HD. But instead the set with one router and two satelites, get two routers and connect them wireless to a mesh. The routers have 4 LAN ports you could use then, like the Orbi..
- Retired_MemberFeb 22, 2017
I'll look into the Amplifi. Thanks.
