Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
bobby35ny
Feb 26, 2017Star
How is the switching from satellites ? The ampli HD as issues too
Retired_Member
Feb 26, 2017Haven't noticed any issues. Seems to switch just fine depending which one has the stronger signal. I do notice they aren't as strong as the Orbi, but you get three so that fixes that issue. Speeds are great on all of them as well. I couldn't tell it to use 192.168.1.XXX network, so it had to use 192.168.7.XXX and I had to change a couple of my devices and reboot some others for them to start working again. So far, no drops at all.
