Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
dsc_dewain
Feb 27, 2017Guide
I literally watched my android phone drop network connection multiple times right in front of me, couldn't believe my eyes. The signal was very strong also. Only 20ish feet from the router. And my firmware is latest. I have joined the others by turning off the beam to see if it helps.
- stavrosgFeb 28, 2017Star
How did the diabling of beam forming work for you in the end?
