Retired_Member
Jan 24, 2017Almost officially done with Netgear Orbi and their support due to not fixing the wifi issues
I am done waiting not hearing anything back from their engineering team to fix this issue. It's been 3 weeks now with no fix. I pretty much told them, they have till Feb. 10th before I purchase a d...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Yld2rob
Mar 19, 2017Luminary
Right now it's solid. Beamforming is not on. Haven't tested that yet. But MU-MIMO is on.
Retired_Member
Mar 20, 2017Looks like per your post in another topic, it isn't solid. Using it in only AP mode is not a fix but a work around and not acceptible for a package like this.
2017-03-19 08:36 PM
You are correct. I had the exact same problem. You need another router and put the orbi in AP mode until Netgear fixes the issue
- Yld2robMar 20, 2017Luminary
It is not acceptable Netgear launched this product way too early. But, I know using this device in AP mode right now is the best option of all other options out there. I get extreme coverage and throughput. Once they do decide to fix it, I will just remove my FIOS router. The key is that it works. Not more complaints from my family.
