Superpop
Jan 16, 2017Star
Alternative to Orbi
Getting frustrated with the constant drops on my IOS devices, wondering if it is time to take the Orbi back to Costco and get something else. I have a 4000SF house, wood construction and Ethernet dr...
Rustproofcorn
Jan 17, 2017Luminary
I'm gonna give djc6 a kudo for his default settings remark. I been sayinf and thinking the same thing. Til netgear fixes enjoy awesome wireless without mimo. The implicit beamforming isn't needed anyhow unless U have a specific device that works only with that specific beamforming. Most n devices work better and more stable with explicit anyhow. I almost took djc6's kudo away for his name tho. Was hard to remember.
- SuperpopJan 17, 2017Star
OK, so I am going to run with Beamforming and MIMO turned off for a few days and see if that settles things down.
- Yld2robJan 18, 2017Luminary
I have tried everything as well. Going back to Costco today.
- Yld2robJan 22, 2017Luminary
I went back to Costco and exchanged the orbi.. i just installed it. We shall see what happens. The Orbi router is connected directly to the Fios connection.. I am not using a FIOS router.
- tucsonticoJan 21, 2017Virtuoso
Superpop wrote:OK, so I am going to run with Beamforming and MIMO turned off for a few days and see if that settles things down.
Any luck with beamforming and MIMO turned off?
I discovered that I left the 2.4gHz channel selection set in "auto". By locking it to channel 6, I've gotten much better stability on my 2.4 gHz devices. I will do a more indepth signal analysis to see if channel 1 or 11 will be better. However, my nearest neighbor with potential interference is several hundred feet away. BTW, my 5 gHz band has been locked in channel 48 with good stability and range since installing the ORBI 10 days ago.
