SLK-Purdue
Oct 21, 2021Luminary
Always practice your disaster protection plan!
After a 50+ year career in IT, I religiously believe in backups. More importantly, I believe in practicing reloading your backups as part of your disaster protection plan. I back up EVERYTHING and...
SLK-Purdue
Yes, running ORBICFG on your backup will tell you if it is good. Normal output will be ASCII commands. When NVRAM get corrut, you get very obvious non-ASCII crud in the output.
Scott
CrimpOn wrote:Thanks for the effort on this. Time to install a C compiler. The gist of this appears to be:
Plan A.
- Make a configuration backup every time there has been a change to the Orbi configuration
(add anything to or edit a device table, change advanced setup parameters, allow/block devices, modify DNS, etc. etc.)- Keep a log of every change made to the router.
- Keep the previous (good) version of the cfg file until the new cfg file has been validated.
- Test each new cfg file for integrity - how?
* Does the orbicfg tool indicate corruption in an obvious, quick way? (have not installed it yet)
* Loading every cfg file on the spare Orbi would verify integrity, but many users have no spare router.- When the latest cfg file is corrupt, perform a Factory Reset, load the previous (good) cfg file, use that log to make the last changes, and resume until the next time a cfg file is corrupt.
Plan B
- If the 'good' cfg file will not load:
- Factory Reset, and
- Configure the router manually.
CrimpOn
Oct 21, 2021Guru - Experienced User
SLK-Purdue wrote:
Yes, running ORBICFG on your backup will tell you if it is good. Normal output will be ASCII commands. When NVRAM get corrupted, you get very obvious non-ASCII crud in the output.
This is SO FUN. I have not found non-ASCII characters in the output (yet), but discovered that line 1 of my output reads: "=666951560373216". Notice there is no parameter name. I guess that it might load (??), but what would the Orbi do with that first line?
My "go to" tool for comparing files is WinMerge (https://winmerge.org/ ) I redirect standard output to a text file which can be sorted or fed into WinMerge. Every difference gets highlighted. I plan to make a backup every day for a while and "see what changes" from one day to the next. (My previous backup was last August on V2.7.2.106, which is a completely different firmware release.)
For those not comfortable with running C programs on Windows, I complied orbicfg on Windows 10 with the "Tiny C Compiler" (tcc). The exe file is here: https://www.dropbox.com/s/3w1pss8hqk9c2q3/orbicfg.exe?dl=0
I am wondering if in addition to validating the checksum (which might be what causes the Orbi upload configuration operation to fail), what code could be used to report non-ASCII characters to standard error? Something in the while loop at line 66?
- SLK-PurdueOct 21, 2021Luminary
That first line looks wrong. Haven't seen that before.
You are going to be surprised about how much changes in "normal" operation.Scott
CrimpOn wrote:
SLK-Purdue wrote:Yes, running ORBICFG on your backup will tell you if it is good. Normal output will be ASCII commands. When NVRAM get corrupted, you get very obvious non-ASCII crud in the output.
