ykcharrier
Mar 09, 2018Aspirant
Am I experiencing firmware issues?
I signed on this morning to find Security Certificate errors when opening my browser. I checked my internet connected and found limited connection. I have a RSR40 and (2) RBS49 satellites. Every...
- Mar 09, 2018
Glad you got it figured out.
Enjoy Now.
Retired_Member
Mar 09, 2018Why are you using the Verison MiFi router?
ykcharrier
I use the Verizon MiFi router because Verizon is my ISP.
- Retired_MemberMar 09, 2018
OK....I assume it's a requirement. Another example of ISP control mesaures. Reading over the number of folks that have problems 'most' are using the Orbi as a second router.
If there is anyway you can ditch the Verizon router, I would do so and run your connection straight out of their modem. But that's probaly not possible.
Good luck
- ykcharrierMar 09, 2018Aspirant
The MiFi is my modem.
I've now turned off the closest satellite forcing my laptop to connect to the Orbi router and have a connection. However, as soon as I turn the satellite back on, I lose my internet connection.
