cdzo72
Apr 18, 2020Apprentice
Amazon appstore being blocked
Hello to all. Ok, while I am connected to my Orbi WiFi, any device is unable to access the Amazon appstore. I have disabled Disney Circle and Netgear Armor, leaving the Orbi to run without 3rd party a...
CrimpOn
Apr 18, 2020Guru - Experienced User
Sorry to be so ignorant. Is the Amazon "appstore" the same thing as "Amazon Shopping"? I have only Android devices, and when I search Google's Play Store to load the app, I do not find one called (specifically) "Amazon App Store."
- cdzo72Apr 19, 2020Apprentice
You have to download the app from Amazon directly I think. To answer your question though, no, they are not the same thing. There is the Amazon Shopping app and then there is the Amazon Appstore app, but that's not a problem, opening the app and getting as far as seeing the apps is possible, just won't let me download anything using the app on my handheld devices. But seeing as the problem persists on the Firesticks accessing the same apps, just from a difference and device, the destination they both call to must the same or under similar urls.
The issue is that when you actually get into the apps on the Appstore and choose Install a message pops up saying that the payment has been declined.
On my FireStick, the problem manifests its way that it blocks the traffic from the Firesticks being able to load apps from the Amazon Appstore. On Firesticks below the Recents row there is a row that has all your installed apps. Also, if you long press the Home button, a screen comes up that allows you to see your apps kinds of like the apps screen on an Android phone or iPhone... with the FireStick connected to my Orbi WiFi I get a message that says authentication error occurred...
If I disconnect ANY of these devices from Orbi, the problem disappears. My cell phones if connected to their 4G networks can then install from Amazon. The FireSticks, if I connect them to the HotSpot on any of my phones, that app row I mentioned and the apps section are then populated.
Once I switch back to Orbi WiFi, the problem reemergers.
- CrimpOnApr 19, 2020Guru - Experienced User
I seem to recall a recent post about Amazon Prime streaming that was resolved by eliminating a "Double NAT" problem.
Is the Orbi (a) in "router" mode, and (b) connected to an ISP modem that is also a router?
- cdzo72Apr 20, 2020Apprentice
I am running a dual wan setup through an Edge Router Lite 3. Running into that are my 2 ISP FTTH connections which are set to bridge only. NAT masquerade is setup for the dual wan setup on the EdgeRouter. The EdgeRouter provides a static local IP to the Orbi. How do I know the Orbi is the issue... any other router I connect behind the dual wan works perfectly without touching a single setting in the EdgeRouter. Zero issues of any kind for VOIP calls, streaming, downloading, zero issues. I connect the Orbi and issues immediately arise.
